Where to jump 12V switched wire for wideband
Old Oct 15, 2009 | 10:30 PM
onefastmx5's Avatar
I bought an autometer wideband. I ran the wires for the o2 already. I've read the radio "red" wire is one I can jump. In the instructions, it says the wire needs to output 13.5V in order for the heating element in the o2 to come on. Am I safe jumping off the radio wire, or is there a better spot?
Thanks,
James
Old Oct 15, 2009 | 11:04 PM
crazypurgatory's Avatar
Lightbulb
Thanks,
James
My 97 has a empty space where you can tap into the ignition in the fuse box.
I'm pretty sure that will have 13.5V.
You sould have an empty space too.
Old Oct 16, 2009 | 02:13 PM
bobdec's Avatar
The '94 has an ign tap in the inside fuse box right next to the 5 amp IP Dimmer fuse, you need a male spade type terminal to connect to it. I'm not sure where, if at all ,that tap is fused, so you should add a fuse to the line if you go that way. I have also used the rear window defogger switch as a handy spot, think it's the heavy brown wire but not sure. Radio fuse may not be big enough to supply both radio and O2 heater, that's a guess w/o knowing current needed for heater.
Old Oct 16, 2009 | 06:40 PM
onefastmx5's Avatar
I ended up tapping off of the yellow wire, back of the stereo- 13.8V and put an inline fuse of 3 amps. Works perfect.
Old Oct 16, 2009 | 08:28 PM
Fuse box. No "tapping" necessary. Just get a 1/4" female spade connector and slip it over the spade lug marked "IGN".
http://www.injuneer.com/images/photo...r/DCP02496.jpg
The Firebird fuse box is "upside down" compared to the Camaro fuse box.
Old Oct 16, 2009 | 10:41 PM
onefastmx5's Avatar
Ah, Injuneer that is what I wanted to know earlier. Oh well, I'll keep that in mind for the next accessory
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
robcarnut
Mar 20, 2015 03:40 PM
Omega9
Aug 2, 2002 12:33 AM
chewy41
Jul 28, 2002 11:20 PM
