Where is extra advance coming from?
Old Jun 13, 2004 | 11:54 AM
  #16
Highlander's Avatar
From what i have gathered the IAT vs Timing table appeared in obdii 96/97 lt1s and there after...
that must be hardcoded in the OS if it where a IAT thing...
But i feel there is such a table...
Old Jun 27, 2004 | 10:49 AM
  #17
Dan K's Avatar
From what I've seen of timing vs. coolant temp tables, they don't start to "kick in" until the coolant temp gets rather high. So they probably aren't a factor.
Now timing vs. IAT would be a different story. If someone wanted to break down the code in the pcm they could find it. Maybe we should ask Tunercat if such a table exists? Heck, they found the forced tcc lock table that I was sure existed...maybe they'll find this too.
Only thing is this, whether it's july or december I still get the same amount of "mystery" timing at wot. So I'm doubting this would be the source as I'm sure the IAT temps are a little warmer in summer.
Old Jun 27, 2004 | 02:30 PM
  #18
Highlander's Avatar
Tunercat assures me there is not such a table, which i know there has to be... i guess i'll run the disassembler to see what i can find...
Depending on how the table is setup you wont get any extra advance wether summer or winter... so that will depend.. but look at it this way... people use the IAT mod to get more power
timing and fuel
Old Jun 28, 2004 | 10:25 AM
  #19
Dan K's Avatar
Ok , technically you won't.
But watch IAT's in warmer and cooler weather and tell me that there isn't a difference.
Old Jun 28, 2004 | 10:59 AM
  #20
Highlander's Avatar
There is.. but what if that table is filled with +4 in the complete table?
Old Jun 28, 2004 | 11:53 PM
  #21
Dan K's Avatar
If that were the case then why are we even having this discussion?
There would be 4 degrees of timing added in above what is shown in the 2 main tables.
I guess I understand what you're getting at, but odds are if there is a IAT vs timing table it isn't filled with the same value.
Old Jun 29, 2004 | 12:01 AM
  #22
Highlander's Avatar
If you check uot the ls1s.. on the working range is more or less zeroed out..
Old Jul 1, 2004 | 05:29 AM
  #23
SABLT194's Avatar
Are we sure that the added timing reported in datamaster is real?? Anybody ever checked w a timing light. I believe some of the older TBI and TPI PCM's had a table for PE Timing Addr vs RPM. I'll have to look again to make sure. Maybe I've killed too many brain cells.
Steve
Old Jul 2, 2004 | 12:12 AM
  #24
Highlander's Avatar
The pe timing could be... as there is one in the ls1s but im not really sure as this advance is seen all around.
Old Jul 6, 2004 | 12:59 AM
  #25
bunker's Avatar
I was thinking it can't be IAT timing table unless its based on RPM because its not just 4* everywhere, it adds 2* at 3000rpm, 3* at 4500rpm & 4* at 5500+ rpm or something rather.
Old Jul 6, 2004 | 01:36 AM
  #26
Highlander's Avatar
Well... on ls1s is a vs g/cyl.. but.. hm...
it could be an adder for the PE vs RPM thing...
but i can see this advanced added regardless im WOT or not.
Old Aug 18, 2004 | 12:44 AM
  #27
cmillard's Avatar
Re: Where is extra advance coming from?
The timing you're seeing in Datamaster is real.
There is a universal spark adder at upper rpms that both LT1edit and tunercat refuse to admit, however I know of 2 guys that agreed on the section in the disassembly where it's at. Basically plan on 4 -5 degrees getting added in the upper rpm band.
Since it's also added to the factory spark values just move values relative to stock.
Doesn't matter what the number is, just how much you had to change it to make the engine perform better.
Oh, the IAT temp tables are only for extreme climate differences, nothing for normal climates.
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
