VE Master!
Old Jan 14, 2004 | 08:34 PM
InjectedSS's Avatar
VE Master!
Whats the deal, this program doesn't work worth the crap Unless Im doing something wrong which I can't seem to think I am.
I enabled speed density in the switch table. Have my MAF removed. Logging with datamaster, the Short Term BLMS are at like 80, subtracting a $hit load of fuel.. I log like a couple of minutes of data with the car idleing in closed loop, run the file thru ve master and it shows that it didn't change crap in the little log What the Hell? It should have lowered the numbers a ton, but it did nothing..
What's the deal?
Old Jan 14, 2004 | 08:37 PM
Sean94Z's Avatar
When I used it, I had to use with a lot of logging, like 10-15 minutes of driving, then do it..
--Sean
Old Jan 14, 2004 | 11:16 PM
Dan K's Avatar
I'm pretty sure VEMaster will not alter anything that occurs in cell 16.
Just do the idle stuff by yourself. Get it sorted out and then take a 20-25 minute log of part throttle and run vemaster on it. Usually 2 or 3 times is enough to get you close. Then just go in and look at the 2 ve tables and make sure that the cells seem go "flow" or are somewhat linear...meaning that the values get higher as map and rpm increase.
Old Jan 14, 2004 | 11:28 PM
InjectedSS's Avatar
Ahhhh that makes sense... Cell 16 being the idle cell
Thanks dude, you da man
Old Jan 15, 2004 | 08:29 AM
MentalCaseOne's Avatar
I am so lost here. My car idles with Block Learn cell 1.
are Block Learn Cells the same as the ones you mention in your
post?
Marvin
Old Jan 15, 2004 | 05:39 PM
InjectedSS's Avatar
post?
Marvin
Not sure what your asking, but your car should ALWAYS idle in cell 16. I don't know why it wouldn't be in that cell if you say it isn't. What are you using as far as scanning goes?
Old Jan 17, 2004 | 04:02 PM
AutoXray EZ-SCAN 6000 their top of the line scanner with software recently updated to their latest.
Marvin
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
