Tuning for a stock engine
Old Nov 28, 2010 | 10:45 AM
MichiganSkip's Avatar
what's the changes you'd make to the fuel and ignition tables on an unmodded LT1, w/4L60E to gain a few tenths?
Old Nov 29, 2010 | 11:10 AM
bobdec's Avatar
Re: Tuning for a stock engine
Are you set up for DIY tuning (laptop, s/w and ALDL cable) ? Here is a site that can help, http://www.lt1pcmtuning.com/ click on "Free Tips" You will need a data logging s/w to see how your engine is currently performing (AFR, knock,etc) then look at timing, and fueling tips. If you click on the "Get Tuned" tab you can see that you can get an e-mail'ed OBD1 power tune for about $70.00 if you have a laptop and cable. So you have a choice, depending on how much you want to do, either DIY on your own or purchase. I have done both, purchased a power tune that set up timing, fueling and shift points for my mods and then tweaked other less complex settings to customize it for my driving preferences.
Old Nov 29, 2010 | 03:47 PM
Thanks Bob, you have a PM. I have TunerCat, and a DynoJet WB that I use.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Jlo
Feb 3, 2015 09:41 PM
rockync7
Jan 1, 2015 05:10 AM
