tuning options for the LT1
i have been looking for a list of the different tuning options for the LT1 for awhile now, but I havent found a good comprehensive list.
so i decided i should start a thread and get all the info in one spot.
so far here is what i have come up with:
PCMforless:
mail order tune
uneditable by the user/owner
price ~$190
http://www.pcmforless.com/index.php?...tpage&Itemid=1
LT1 Edit :
stock pcm hack
vin locked (ie can only be used on your pcm)
Current pricing for the package is $200 and up, depending on the options purchased.
http://carputing.tripod.com/
Tunercats :
stock pcm hack
no vin lock
pricing - $70 for the tuner version, $100 for the reat time tuning version
limited to 100 kpa (for boosted cars)
http://www.tunercat.com/tnr_desc/do_tc.html
Big Stuff 3:
Stand alone ECU
not plug and play (that i know of)
tons of options
pricing : $2,689.99 ish
http://www.bigstuff3.com/index2.html
FAST:
Stand alone ECU
Not plug and play (that i know of)
ton of options
pricing : Base system prices begin at $1546.83 and go to $2500+ depending on options
http://www.fuelairspark.com/
Autronic:
Stand alone ECU
ton of options
pricing : Base system prices begin at $1800 and go to $3800+ depending on options
http://www.autronic.com/index.html
Accel DFI:
piggyback system
pricing- i couldnt find the v8 pricing
http://www.accel-dfi.com/ProductDeta...minselection=0
please feel free to correct anything on here,
id like to get a master list going so the more help the better.
im sure there are others out there that i didnt put on the list.
add anything you want and ill update the list.
PCMforless:
mail order tune
price ~$190
LT1 Edit :
stock pcm hack
Tunercats :
stock pcm hack
no vin lock
Big Stuff 3:
Stand alone ECU
tons of options
FAST:
Stand alone ECU
ton of options
Autronic:
Stand alone ECU
ton of options
Accel DFI:
piggyback system
You might want to edit with information about software for 1993 ECMs vs ODBI 94-95 ECMs and the ODBII 96-97 ECMs. They each use different tuning software.
IE, you can use TunerPro and TunerPro RT along with cables from moates.net to tune the 93 ECMs.
Tunercat is now ODBI only - the Tunercat ODBII software is now distributed by Jet under the name "Dynamic Spectrum Tuner".
LT1 edit comes in different flavors and prices for the ODBI vs ODBII versions.
snake - i added in pcmforless, but i wasnt able to find any info when i googles madztune.
if you have some info , post it up and ill add it.
kyle- i was trying to keep this semi short and sweet.
id prefer to not have to add in pricing/options for each different model.
if you want to write up ill edit it in though.
i am mainly trying to make a one stop list for people to use for their research.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
