tuning my 93
Old May 5, 2010 | 07:28 PM
TM2S3's Avatar
tuning my 93
Hey,
I have a 93 z28 with a cam and some other mods, and have a pcmforless tune. I am happy with their work but would like to get a dyno tune. The problem is I cant find anyone in the Houston area that can tune my camaro, so I was curious if anyone here had any recommondatons on chip burners and the proper software to tune my car.
Thanks,
Old May 6, 2010 | 08:51 AM
bobdec's Avatar
You can start here http://support.moates.net/ Under Tuning menu click on GM Tuning , then click on GM 86-95 (read me) . Also a couple of other forums http://www.speeddensity.org/forumdisplay.php?f=16 and http://www.thirdgen.org/techboard/diy-prom/ can help out. Lots of reading Good Luck. And if you want to try another mail order http://www.lt1pcmtuning.com/service/ is good. None of these will probably work as well as a good dyno tune that will run $400-600 , figure 2-3 hours of a skilled technician, shop supplied burning/emulator tools, dyno time, chips and adapters for your PCM.
Old May 6, 2010 | 04:11 PM
TM2S3's Avatar
Old Jul 4, 2010 | 11:47 PM
TM2S3's Avatar
My plan now is to get the APU1 from moates, and tunercats. The only thing now is I was reading about an emulator, so I dont have to burn through chips to get the tune right. I dont know much about emulators, so if anybody has some knowledge on that, I would greatly appreciate it.
Old Jul 5, 2010 | 02:38 PM
JSK333's Avatar
The APU1 comes with easy to follow instructions. Using CATS RT OBDI Tuner, it's very straight forward. You can set it to auto-update when you make changes to the tune, or only when you hit the "upload to emulator" button. I've used it to tune my '90 Cadillac which is a TPI-style ECM. It really works great!
The other thing is that the 27SF512 chips are flashable, so you can erase and burn the same one over and over.
Old Jul 5, 2010 | 03:45 PM
TM2S3's Avatar
Awesome! That makes things a lot simpler than I was expecting.
Old Aug 11, 2010 | 07:39 PM
plattted's Avatar
tuning
How is the tuning on your "93 going?i am in the same situation with simular mods and would like re tune.
thanks, ted
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
