Tuning Help
Old May 21, 2007 | 10:58 PM
  #16
turnin20s's Avatar
Originally Posted by 2xLS1
Try some NGK TR55s. No fancy platinum or irridium. Just their standard copper core plugs. $1.49 ea around here. You need to find the cause of the plugs fouling. Are they fuel fouled or oil fouled? Is this on a stock tune or modified? Do you have tuning software? Have you ever checked what your WOT A/F is with a wideband?
Tune was done by Ion at mad2z8.com for my mods. Sorry no tuning software and I don't have a wideband to check A/F ratio. And my plugs are fuel fouled, I could go pull one out right now after the car has been sitting since Saturday night and it will smell like gas and if I run the car and pull a plug it will be wet. I think my pushrods being too long are keeping the valves open when they should be shut.
I'm really thinking that its my pushrods being too long, I'm pretty sure I ordered the wrong ones but I'll make sure wednesday and order the correct length pushrods wednesday afternoon and hopefully have them by Friday.
Would the pushrods being too long make the car really rich? It would explain why its soo hard for me to get the correct preload.
Old May 22, 2007 | 09:55 AM
  #17
2xLS1's Avatar
You would have low compression if that was the case and backfiring in the intake and exhaust. LT1s have an adjustable valvetrain so too long a pushrod will effect more where the rocker arm contacts the valve tip rather than what you think is happening. You would have to have all the inner pistons in the lifters bottomed out for the valves to be hanging open.
Old May 23, 2007 | 10:24 AM
  #18
turnin20s's Avatar
Ok I ordered the MAP pigtail and the new wireing harness for the Opti and I'm going to check the pushrod length tomorrow when I get some time. Then I'm going to change the plugs again. Once I get all of that done and the new pushrods installed if they are needed I'll see how everything works and post another datamaster scan to see how everything is working.
Anyone have a suggestion for the gap on the plugs? I gapped my other plugs to .050, but should I go smaller?
Thanks again for the help guys, I really do appreciate it.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
