tuning for a 58mm tb
Old Oct 26, 2003 | 12:23 PM
  #16
Dan K's Avatar
That makes sense. It's just opposite of what I was thinking.
The fact that more air in with the bigger tb resulting in more rpm wasn't clear in my head.
But with a bigger tb=more rpm at the same tps then you would have lower line pressure at a higher rpm than you did before the tb swap.
Thanks!
Old Oct 26, 2003 | 12:30 PM
  #17
Schurters LT1's Avatar
This may not be the place but, Ion & Dan with all the tuning that you have done can you put on a TB to big and hurt performance or is like i posted above as long as the car is tuned youre fine
thx this is great info it was not out there before nor i could not find it
Old Oct 26, 2003 | 03:10 PM
  #18
madwolf's Avatar
Yes, you can hurt performance if you put a (significantly) bigger TB than needed. The car will tend to bog down whenever you try to go WOT.
There's a formula here somewhere for figuring out how much air your engine needs and how much various TBs will flow.
Old Oct 27, 2003 | 04:09 PM
  #19
johnny o's Avatar
Schurters LT1, you should check out www.kwfbody.com if you haven't already since your from KW.
Old Oct 27, 2003 | 04:18 PM
  #20
johnny o,
thx
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
