Tunercat WOT tuning
Old Nov 28, 2010 | 07:39 AM
mightymouse383's Avatar
Tunercat WOT tuning
Which table in TC is the one for tuning WOT?
Old Nov 28, 2010 | 11:06 AM
bobdec's Avatar
Re: Tunercat WOT tuning
Your sig says '97 so you either have an old TC OBD2 program or you converted to OBD1. Following is a cut/past from the ODB1 TC version 2.3 Help screen, it is not in the newer TC beta version 3.24 somehow it was eliminated.. If you are TC ODB2 then just disregard as I can't answer for that version..
WOT % Change To Fuel/Air Ratio Vs. Coolant Temp.
This table is the percent change to Fuel/Air Ratio used at or near wide-open throttle (WOT) versus coolant temperature. The values from this table and the WOT % Change To Fuel/Air Ratio Vs. RPM are summed to arrive at the WOT Air Fuel ratio.
The resulting air / fuel ratio can be calculated as follows:
WOT AFR = 14.7 / (1 + %Change vs Cool/100 + %Change vs RPM/100)
For the selected RPM, suppose the percent change to Fuel/Air Ratio from the RPM table is = - 5.1 and the percent change to Fuel/Air Ratio from the COOLANT table at the selected coolant temperature is = 22.7, then the approximate WOT AFR would be:
14.7 / (1 -0.051+.227) = 12.5:1 AFR
Also there is a "TPS Threshold for PE Vs RPM Vs Coolant temp" table that sets when you enter WOT (PE mode) in case you want to enter WOT at different parameters for your setup.
Old Nov 28, 2010 | 08:56 PM
Thanks Bob, I will start to tune alittle more once my wideband gets here, Yes I did convert to OBD1 and have TC 3.24
Aug 24, 2015 06:41 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
whitehooptie
Jul 22, 2015 10:25 PM
