Tunercat table for PE or WOT fueling
Old Feb 12, 2010 | 04:23 PM
mightymouse383's Avatar
I need to know what table in tunercat do I have to play with when tuning for WOT?
Is it "%change to afr vs rpm". I am picking up a wideband soon and am trying to learn before hand.
If that is the table, will increasing the % add fuel or remove fuel?
Old Feb 12, 2010 | 04:39 PM
Airbornec507's Avatar
"% Change to Fuel/Air ratio vs RPM at WOT" is the table. Yes adding to the number adds fuel. However there is more to tuning than just the WOT table. Sure if your happy with the way the car runs during normal street driving now and you confirm you A/F ratio for street driving via the Wideband while your BLM's are close to 128 Long Term on both banks then yes it would be time to tune the WOT table. Here's a link you should read to get an understanding first: https://www.camaroz28.com/forums/sho...d.php?t=505190 Once you've done that PM me your email and I'll send you an excel spreadsheet that will do more for you as far as tuning the WOT table by trial and error. It uses the actual mathematical equations based on what your currently at and gives you a new input value for your PE tables based on what A/F ratio you want to be running.
Old Feb 13, 2010 | 09:05 AM
Cool!!! I will E-mail you when I get to that point.
Old Feb 24, 2010 | 07:39 PM
Doc87IROCZ's Avatar
mightymouse383; I have been tuning my '87 Irocz and my '99 SS for many years now. You are not too far away from me, Mims, Fl. Maybe we can hookup someday, I think that I can help in some cases. Do you run a scanner to "see" what the engine is doing while you drive?
DirtyDaveW
Dec 1, 2016 05:37 PM
DSMKilla
May 26, 2015 10:10 PM
BigWil
Mar 29, 2015 12:24 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
jayblev95
Jan 20, 2015 01:30 PM
