In tunercat... Which is the PE table?
Old Aug 9, 2002 | 01:16 PM
Highlander's Avatar
Post In tunercat... Which is the PE table?
Which is the PE table in tunercat?
94B4C M6
Finishing project
Borla Competition--
AFR Heads
383 + Paxton Supercharger
Old Aug 9, 2002 | 02:30 PM
GetaZforgetGT's Avatar
Post
I've been wondering the same thing.
It would be really cool if someone that knew both programs could create a quick reference table that put comparable tables together.
Any body qualified for that??
Jeff
95 Z28
A couple mods, nothing worth mentioning though
Old Aug 9, 2002 | 07:08 PM
Dr.Mudge's Avatar
Post
You have two
1) %Change To Fuel/Air Ratio Vs. Cool Temp @ WOT
2) %Change To Fuel/Air Ratio Vs. RPM @ WOT
For the dyno I took the 68º reading in PE vs. Coolant Temp (#1) and pasted it into the higher temps as well, to keep the readings from changing on me while tuning. So from there to get my AF to 13.0:1 or so I used the second mapping, and worked with PE vs. RPM (#2).
DirtyDaveW
Dec 1, 2016 05:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
MichiganSkip
Jun 8, 2015 10:30 AM
dayusmc
Oct 19, 2002 07:06 AM
Highlander
Sep 25, 2002 09:22 AM
