tunercat/ Knock sensor
Old Sep 30, 2005 | 04:40 PM
Honda Hunter's Avatar
How do I desensatize or turn of the knock control using TC?
Old Oct 1, 2005 | 02:06 PM
infinitebird's Avatar
Re: tunercat/ Knock sensor
There are like 5 tables that relate to this I believe.
Knock Fast Attack Rate vs. RPM
Knock Retard Recovery Rate vs. RPM
Max Knock Retard vs. RPM (in P.E.)
Max Knock Retard vs. MAP (non P.E.)
Burst Knock Retard vs. Coolant Temp
Then there are like 4 more that relate to low octane. They all start with "Low Octane" followed by something. So if you are wanting to do this because of running a lower fuel grade use those instead of the above ones.
Old Oct 2, 2005 | 09:22 PM
smoknta's Avatar
Why would you want to turn of you knock control? You can seriously damage you engine if you are getting real knock.
Old Oct 3, 2005 | 12:24 AM
Lets be serious. I own a Mustang that at one point made 500rwhp. It was a 97 sohc which dont come with knock sensors. My point is alot of cars dont have them and get by just fine. I wanted to turn mine off until I was able to get the issues worked out but Im ok now. My biggest issue now is I have a LT1 KM and I hear it's way to sensative for my mods. Now I just want to desesatize it using TC.
Old Oct 3, 2005 | 03:54 AM
smoknta's Avatar
Are you getting knock? With your 94, you can get a LT4 knock module that will desensitize the knock control. That is what most people will do. I would not advise on turning it off, but thats your call. I know alot of cars dont have it, but alot of older cars dont have rev limiters. Does that mean you dont need one of those to? To me its just one more way to protect my investment. If your getting false knock, just find out what it is and fix, the same with real knock. The LT4 knock module is a great way to desensitze after modding your motor, especially with aftermarket rollerrockers and headers.
Old Oct 3, 2005 | 06:36 AM
I only wanted to turn it off until I was able to fix the sensor itself, now it's fixxed. I know most people use the lt4 km but couldnt the same thing be achieved through the computer with tuning? Either way the LT4 km isnt that expensive so I hope to have one soon. My tuner was suppose to send me one but I dont know what happened.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
