TunerCat A/F Ratio Spreadsheet
Old Oct 23, 2003 | 12:23 AM
97bowtie's Avatar
I created this spreadsheet and I figured some of you could get some use out of it.
Change the values in the two tables at the top of the spreadsheet. These are the same two tables you will see in Tunercat; 1. % Change to Air/Fuel Ratio VS. Coolant Temp at WOT and 2. % Change to Air/Fuel VS. RPM at WOT. This makes it much easier and quicker to tune. Once you have the tables the way you want them, simply copy and paste the values from excel back into tunercat.
Air/Fuel Calc. Spreadsheet
Enjoy.
Old Oct 24, 2003 | 02:36 AM
InjectedSS's Avatar
dam you posted over here now and I see these fool's don't know WTF this thing does either LOL buncha poosy's
Old Oct 24, 2003 | 03:09 PM
Wild1's Avatar
I've got Tunercat, but never tried this table. Can it convert to F or is everything in Tunercat in C?
Old Oct 24, 2003 | 07:39 PM
Dan K's Avatar
You're joking right?
You do know that a spreadsheet like this is nothing new and there are others that do the same thing.
There is even a more advanced version that Chrisitan Millard wrote that allows you to use this inaccurate data along with actual a/f data from a wideband to tweak the pe tables.
Old Oct 24, 2003 | 09:01 PM
Wild1's Avatar
I'm new to this... are these tables bad? What part of the data is inaccurate?
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
whitehooptie
Jul 22, 2015 10:25 PM
