TunerCat - 350 to 383 - Questions
Old Jun 9, 2010 | 03:25 PM
Wild1's Avatar
I have a '95 Z28 that is now a 383. There are a few questions that have surfaced while tuning. I have used a smoke machine to find leaks in the intake (none found). FYI - The location for the smoke machine insertions were at the dipstick, on the vacuum port for the HVAC controls, and on the cold air intake system in the vacuum port for the Opti... no leaks.
Also, I have checked for exhaust leaks using a Seafoam Treatment, no leaks to the tailpipe.
1) I am getting lean intake pops (backfires) when the throttle tips-in. Typically, software has an accelerator tip-in table so that there is a brief enrichment of fuel during acceleration. I can’t seem to find this table in TunerCat.
2) Also, I’m getting exhaust pops on deceleration. What can be done? Which table? Deceleration is keeping the car in gear (Manual M6) while decelerating.
3) My VE Tables are maxed at 99.6. I have checked for exhaust leaks using smoke and there are no leaks. Also, the intake was sprayed with Brake Cleaner while watching the Fuel Trims in DataMaster, no intake leaks were found. The engine was a 350 and has been bored/stroked to a 383. I have scaled down the MAF values, displacement, and Fuel Injector calculations by 10%. The VE still say 99.6. Any ideas?
4) My Closed TPS vs. Spark Table is set to 28* Advance, however my DataMaster is saying 23* Advance with no spark retard. Why?
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Collector Car
Dec 17, 2014 01:12 PM
Lederman1976
Nov 30, 2014 05:21 AM
