tuner cat vs tuner cat rt
Old Feb 29, 2004 | 10:21 PM
1FASASZ's Avatar
im getting ready to order a tuner cat, so wich one should i get? does anyone here use the rt version?
thanks
Old Feb 29, 2004 | 10:41 PM
Dan K's Avatar
Pretty sure we can't use the rt version. Although I'd love to be able to change things while the car is running like DFI and such!
Old Mar 1, 2004 | 07:39 PM
1FASASZ's Avatar
well that sucks
Old Mar 9, 2004 | 12:28 AM
sweetassz's Avatar
TC's sight says it will work but you need a $180 Romulator.
Old Mar 10, 2004 | 03:25 PM
SVT Killer LV's Avatar
If I was keeping my Z28, Tuner Cat RT would most definately be a purchase...
Old Mar 10, 2004 | 04:50 PM
97Z-M6's Avatar
sence when.
this is a quote from there site:
Note: The Romulator I only supports EPROM’s up to 256K in size. If you select an ECM Definition File for a calibration that uses a larger EPROM, such as the $0D ECM Definition File, the program will immediately disconnect from the Romulator and revert to normal ‘off-line’ (non-real-time) operation. The Romulator II does support EPROM's up to 512K in size. The Romulator also does not support the FLASH based PCM’s supported by the $EE ECM Definition File.
Old Mar 11, 2004 | 12:00 AM
sweetassz's Avatar
Originally posted by 97Z-M6
sence when.
That is true, but; on the ecm def file page it states otherwise. Here is the link: http://www.tunercat.com/tnr_desc/do_tc.html
Click on rt tuner then on ecm definition file.
Old Mar 11, 2004 | 01:59 AM
DOOM Master's Avatar
K, but can you scroll down a bit more and see where it says exactly what 97Z-M6 already posted?
Now go to www.xtronics.com and take a look at the ROMulator. You will see that it is only an EPROM supporting device at current time. It does not support PLCC-32 FLASH chips. This is a list of all the devices that the ROMulator currently supports:
27(C)16, 27(C)32, 27(C)64, 27(C)128, 27(C)256, 29C256
(27(C)512 PKT-ROM2 only)
No where on either Tunercat's or Xtronics' sites does it say that it will support 94+ FLASH PCMs. In fact, it states the exact opposite on both, and on TC's it is specifically spelled out!
Old Mar 11, 2004 | 10:31 AM
sweetassz's Avatar
All I am saying is their ECM def. file page is misleading. Obviously it is not supported. I did not read the disclaimer when I first posted, thats all.
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 12, 2015 01:53 AM
fift5
11
Oct 1, 2015 10:31 AM
Ks0209
Oct 1, 2015 07:32 AM
Sep 11, 2015 09:44 AM
