TTS Datamaster software
Old Feb 13, 2007 | 03:11 PM
gameparadise's Avatar
Hello, does anyone know if this software is good to diagnose problems? I bought the GM ALDL OBD1 Serial Cable to connect to my laptop and downloaded the software for my car today. I am basically trying to find out why the car starts hard. The shop told me my Optispark failed, but it was just changed just over a year ago. I find it hard to believe its gone again.
The car starts hard, need to pump the gas and hold it down before it starts, and then after it starts, it sounds like the fans are running at high speed. It idles fine and drives fine until I give it gas to overtake. Then its knocking.
Will this software help someone looking at it, to tell me what may be wrong?
Thanks!!
Paul
Old Feb 13, 2007 | 03:31 PM
If you know what you are looking at, it's a great tool.
Old Feb 14, 2007 | 01:28 PM
Ok, I ran a test but only for a few minutes worth of driving. I did get a DTC 36 Hi Res error. I need to put it on a lift first to verify all cables are good. I think the opti is shot!! From what I read on this site, it seems to be the opti.
Paul
Old Feb 14, 2007 | 05:10 PM
DTC 36, by itself with no other symptoms, may not be an opti death sentence. Clear the code, see if it comes back and monitor performance. Check the opti harness cable for connection/corrosion as well.
Old Feb 15, 2007 | 01:31 PM
Thanks Rob. I will do this this weekend. Will let you know the results. Would I clear the error by disconnecting the battery?
Old Feb 15, 2007 | 03:10 PM
You can remove the PCM BAT fuse for about 30 seconds to reset the computer. Easier than disconnecting the battery.
MDZ28
11
Sep 24, 2015 09:15 AM
ZXXVIII
Sep 1, 2015 10:13 PM
Bails098
Aug 17, 2015 05:15 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Joe Brodman
Jan 1, 2003 12:59 PM
