TPS problem
Old Jun 8, 2013 | 12:50 PM
  #16
Re: TPS problem
Just remember... the gauge and the PCM are using two different sensing locations. Maybe the sensor for the PCM is not accurate.
And you did wire only one gauge to the sensor in the head... not two?
Old Jun 9, 2013 | 11:00 PM
  #17
CALL911's Avatar
Re: TPS problem
What kind of TB do you have? Mine has been giving my tuner similar problems, but we have identified that it is indeed the TB (58mm AS&M monoblade).
Old Jun 10, 2013 | 12:26 AM
  #18
detroitmuscle's Avatar
Re: TPS problem
Im running a stock throttle body. Also, i replaced the stock gauge sensor in the head with the autometer gauge. The way you wire it up is only one wire to the sending unit then a ground from the gauge and one power to ignition power. So yes only one wire to the actual sending unit. But that gauge shouldnt affect the fans coming on. So you think i should replace my coolant temp sensor in the waterpump? Thats not a problem but that means it would have to be off by 20 degrees. Is this a common problem?
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
