tcc trouble
Old Dec 7, 2007 | 09:26 AM
billk1's Avatar
tcc trouble
I bought a 94 a-4 with 373s, runs great but tcc doesnt lock up, have a mech, friend who scanned it and he could enable it manually, but pcm doesnt kick it on, also have a donor pcm out of a 94 caprice, put it in and the tcc would work but the donor had 273s and my car idled like **** at first but then got better as it warmed up and drove around but when i turned it off then later restarted it did the same thing all over again, like it had to relearn itself, and the 94 caprice has has 2 knock sensors, whats up with my f-body pcm and why doesnt the donor one work good?
Old Dec 7, 2007 | 01:59 PM
VinceTrifecta's Avatar
Has your speedometer been recalibrated for 3.73 gears? If so, it is possible the TCC lock/unlock tables were not scaled accordingly, or correctly. Also, if there is a problem with the throttle position sensor, or its adjustment, this could cause the TCC strategy to not work correctly.
The B-body cars used a different sized MAF, and as such, the MAF calibration is different between the B and F body cars.
Old Dec 7, 2007 | 11:23 PM
billk1's Avatar
original pcm has been recalibrated, but if problem with tps then why would donor pcm let it work, what has to be done to the MAF?
Old Dec 9, 2007 | 10:29 AM
billk1's Avatar
I still have the maf from the doner, can i use that with the doner pcm?
Old Dec 9, 2007 | 01:17 PM
Yes, although there are other things that are different, too, like the fueling and spark advance maps. But it should at least run a little better with the proper MAF.
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
