swap question about my computer HELP
Old Apr 10, 2003 | 08:14 PM
ponykiller z28's Avatar
i figured which wires needed to be changed to make coil fire and fuel pump to come on but now there's only one problem......
the anti-theft decoder and the resistor in my key does not match up with the v8 computer.... this causes the engine to crank up for three seconds then shut off..... is there any way i can take my car and computer to a dealership and let them reset my computer to match my old v6 key and decoder?
or do i have to get the decoder and key out of the car that i pulled the engine out of?
i appreciate ANY suggestions
Old Apr 11, 2003 | 01:01 AM
madwolf's Avatar
If the starter is moving, the pump is pumping and the coil is firing, then the only problem left is to disable the VATS from the computer so that it allows the injectors to pump. You can do it through either a VATS bypass box, or through programming.
If you're interested, I have a "saver package" which includes disabling VATS and a few other items, for $45.... Check out my website...
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
