Sunpro code scanners?
Old May 21, 2003 | 09:39 AM
SloMofo's Avatar
Question Sunpro code scanners?
I know Sunpro makes a couple inexpensive code scanners.
Any of them any good for LT1 cars?
I have a 95. OBDI PCM w/the OBDII connector
Old May 23, 2003 | 11:45 AM
SloMofo's Avatar
Question
No one has anything to say about them?
Old May 23, 2003 | 02:18 PM
moparman's Avatar
I've got the OBDII one. It works good. Have you checked Actron's site to see what the specs are on the code readers? They've got some new stuff out, so there might be a sale on the older stuff.
Old May 23, 2003 | 04:16 PM
SloMofo's Avatar
The 9001 model won't work with my car because of the OBDII connector. I assume I need the CP9035, correct?
http://www.actron.com/cgi-bin/web_st...=6179199_10626
Old May 23, 2003 | 06:27 PM
moparman's Avatar
No, the CP9035 is OBDII only. Auto X-ray had an OBDI scan tool that could pull codes from the '95. I think it was around $150. You might check their site and see if it is still available. I think the model # is XP240.
Chet1185
Apr 26, 2015 04:07 AM
aj2494
Mar 12, 2015 10:17 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
