Stock tune capabilities???
OK, looks like I'll be getting my HSR now. I have a 355 w/ 10:1 flat tops, stock P&P'ed iron heads w/ 2.02-1.60 valves, a .560/ .560 lift hyd. roller cam, BBK 58mm TB. I'll most likely be spraying a 100-150 shot of juice to it. Will the car run on the stock tune? I'm not wanting to keep it that way, just wanting to know if it will be driveable.
Re: Stock tune capabilities???
If you're still running the stock injectors it will probably idle and run OK for mild cruising. Do Not go WOT without a trip to the dyno with a Wide Band and some PCM editor.
Steve
Steve
