stick with OBDII or switch over to OBDI
Old Sep 14, 2004 | 01:21 PM
Seal's Avatar
i just got a turbo put on my car, and obviously i need a tune now... and need to upgrade the fuel injectors etc... I was thinking of switching over to OBDI because in the long run it will cost me less (my friend has the cables for OBDI stuff, so all i would need is a OBDI PCM) it'll end up running me like 250 or so...
only reason i didnt wanna do this was because if i ever go with a bigger stall...
i guess i'll have to keep my stall at 3 so i wont have the OBDI not shifting problem
so what do u yall think
switch over to OBDI or stick with OBDII and buy lt1_edit for 550 and spend that extra 200 bux?
Old Sep 14, 2004 | 02:11 PM
turbo_Z's Avatar
Re: stick with OBDII or switch over to OBDI
The OBD2 is definitely the better PCM because of all its functions and diagnostic capabilites but I only paid like $150 to switch over to OBD1 with tunercat tuning software. At the time I thought OBD1 conversion was teh way to go but now I wish I would have waited for OBD2 programming software to be released.
Old Sep 14, 2004 | 02:27 PM
moparman's Avatar
I have read many posts on here that if your car is an auto, it is better to stay with OBDII. Someone who knows more needs to chime in.
Old Sep 14, 2004 | 05:10 PM
TriPinTaZ's Avatar
I stuck with OBD2, The savings of going to OBD1 turned out to be about $125. Not worth it if you ask me.
as far as the auto tranny goes, the OBD1 pcm doesnt like stall converters but can easily be programed out.
Save $125 by going to OBD1, but then you have to extract the VIN# from the OBD1 pcm, install a OBD1 konck sensor, and fine a base tune ( if not in the PCM ) to start with.
Old Sep 14, 2004 | 06:48 PM
Seal's Avatar
guess i'll just stick with OBDII then
LT1_edit it is!
Old Sep 25, 2004 | 05:43 AM
mike 96 ws6's Avatar
i'm running OBDI in my 96 with the original OBDII "knock sensor" and the LT4 "knock module" that i was running in my OBDII PCM. what's the difference in an OBDI "knock sensor"?
Old Sep 25, 2004 | 04:11 PM
TriPinTaZ's Avatar
The obd2 knock sensor works on a 100 ohms and the obd1 works on 3.9 ohms. So if you have an obd1 pcm with an obd2 knock sensor your PCM is getting the wrong signal from the knock sensor.
However, Ion @ madz28.com can edit the OBD1 PCM to work with the OBD2 knock sensor.
Old Sep 25, 2004 | 05:22 PM
97Z-M6's Avatar
i like obd1, and i did the switch. the stall thing thats an easy fix, a buddy had a 4400 stall for daily driver and i got it working great for around town and at the track it was awsome.
but i read read somewhere (i think brents site) that the obd1 pcm is better for turbo applications becuase there are some issue with the maf on a obd2 with a turbo it maxes out at 500grams of air per sec. the obd1 doesnot. and now he has know problems.
im sorry im not more clear on this but read his site to find it. i dont have a link maybe someone can post it. sorry.
and to fix the knock sensor it only needs a resistor soldered on the pcm
Old Sep 25, 2004 | 09:46 PM
TriPinTaZ's Avatar
LT1_edit 2.2 for OBD2 has a MAX MAF table that allows you to fix that issue.
IndyZman
Oct 22, 2015 02:17 PM
SEOJustin
Sep 24, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
