Split BLM in all cells, Capped Rich at idle, Capped Lean on Decel
Old Oct 14, 2003 | 11:23 AM
Jason Dove's Avatar
I fired up the car today did some logging, my car is split in almost all Cells. I'm running 30* of timing at idle and pulling in a map of 48. I 'thought' that with that much timing at idle, the Map would be lower, but when I jumped it from 20* to 30* I saw no difference.
Does that sound like there's a vaccum leak?
It's a CC305, 58mm BBK, LT4 Intake/Heads, MTI ported, 383 9.5:1 Compression.
The link below should be pointing to a log:
http://www.geocities.com/fb_nitro/PCM/log.txt
And you can email me at fb_nitro@yahoo.com if you want to see a copy of the program.
Old Oct 16, 2003 | 09:45 PM
stlws6's Avatar
did you try swapping o2s, then try to find leaks on the left side (when sitting in car) on the headers intake everything. then swap the injectors to the other side one might be stuck open.
DirtyDaveW
Dec 1, 2016 05:37 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
maybe2fast
Mar 16, 2015 11:59 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Jul 4, 2005 05:00 PM
