Simple OBD2-OBD1 swap question.
Old Mar 3, 2004 | 01:05 PM
96z's Avatar
96z
Is it imperative that the knock sensor get switched over with the swap? Also can an LT4 knock module still be used in the OBD1 PCM?
Also is the tachometer signal different between the two?
Old Mar 3, 2004 | 03:31 PM
madwolf's Avatar
Yes, you absolutely have to switch the knock sensor unless you modify your PCM so that it works with the current knock sensor. If you don't, you car will set an SES code and retard the KR to max causing very poor performance.
The LT4 KM can be used with OBD1 PCMs.
Tach signal is the same except on Impalas.
Old Mar 3, 2004 | 07:34 PM
96z's Avatar
96z
Beautiful, thanks for the concise explaination madwolf.
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Latronaxe
Jul 20, 2015 12:00 PM
