Shift points tunercat
Re: Shift points tunercat
The ECM constants list has the fuel cutoff and resume listings for rev limit.
The shift points are easily found in the tables list as "normal mode up/down shift points".
You don't have to guess, exactly (you can use an online calculator to determine speed/RPM like http://www.f-body.org/gears/ ).
Normal is normal.
Performance mode is when the performance mode button is engaged (came on 94-95 Firebirds and easy to enable on 94-95 Camaros). My website has a schematic.
Normal is normal.
Normal is normal.
Normal is normal.
Ok. At wot Im set to shift at 6800 rpm's. 1->2 41mph 2->3 78 3->4 127mph
Right now the down shift is 2->1 23mph 3->2 69mph 4->3 114
What would be optimal for downshifts when racing pesky 5 speed sohc Mustangs on the highway and Im allready cruising in O/D.
* Disclaimer street racing and is wrong and should not be done by anyone. *
Originally Posted by Red on Red WS6
Wow either those figures are way off or my tach is messed up. I have stock 3:23 gears and it says my 6100 RPM shift point should be 47 MPH in first gear. In tuner cat I have it set to shift at 36 MPH.
Also be aware that the WOT shifting is apparently determined by the "Kick down/up shift points" not the larger shift point tables.
Normal is normal.
Normal is normal.
Originally Posted by Mean Green Z28
Is there much to gain by having the Performance button? Do you have it hooked up? I've always wondered why the Camaros didn't have it. Will it work on all years?
Chevrolet has always been a cheaper price point motor division than Pontiac. Therefore, Pontiac got the option button.
94-95 only. I use it on my car. There is no gain or difference in WOT performance. It is only meant for part throttle driving to keep the engine revs a little higher.
performance button is the best mod in the whole 'ntire world jimbob. use it for soloII to keep your car in gear longer after you've gotten to the track, use it on cold mornings to keep rpm's down till the engine warms up, use it to save a bit of gas by programming conservative shift points for the daily commute through rush hours.
