ses light for code 43 esc failure? obd1. what does this mean?
Old May 27, 2005 | 10:40 PM
1darkz's Avatar
i flashed my pcm which is an obd1 converstion with a program from pcm4less. my ses light has been on since i did this. i then used freescan to scan the pcm and try and find what the engine light was for. The software showed code 43 esc failure which i think has something to do with knock retard? the knock retard was fluctuating between 0 and 5 degrees and the knock count was climbing the more i stepped on the gas. the car is running very rich also. i was told this could be from the ses code. any help to trace out this problem would be greatly appreciated. thanks
Old May 28, 2005 | 02:42 AM
SteveZ Z-28's Avatar
Re: ses light for code 43 esc failure? obd1. what does this mean?
DTC 43 for OBD-1 is for the Knock Sensor (KS) circuit. It could be a bad knock sensor, it could be a wiring problem, it could be a problem with the knock sensor module located in the PCM, or the PCM could be bad. Your best bet is to follow Shoebox's knock sensor circuit test procedure presented here. Good luck.
Gtpguy
Jan 26, 2015 04:50 PM
squarehead
Jan 15, 2015 07:02 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
