PCM Reset, BLM=120?
PCM Reset, BLM=120?
Everything that I've read indicates that the PCM should default to BLM=128 for all cells after a PCM reset, until closed loop is achieved and actual values replace the default of 128. Well, not on my ride! My car is a '94 'vette, and have had it since new. Whenever I reset the PCM, it defaults to BLM=120, except at WOT, which is 128. It has ALWAYS done this. Normally this wouldn't be much of a problem, but now that I'm doing some tuning with LT1 edit, I'm of course shooting for 128. This also makes open loop opperation a bit difficult as again, it defaults to 120, which is, of course, leaner than 128. I don't know if this a Y body specific thing, or what. The only way I've found to get around this, especially when I'm running an open loop program, is to get my old Tech 1 and perform a BLM reset opperation. After that, all cells are 128. But if I upload a new program (which esentially causes a PCM reset after programming), I'm back to 120 and serching for the Tech 1 again. Any ideas???
Re: PCM Reset, BLM=120?
I'm assuming you mean "constants" table. If so, then I can't find keep alive blm.
I've got version 2.08 of tuner cat and my ecm definition file is ee version u. Am I looking in the right place, or are you using a different version of tuner cat? Thanks for the help, btw.
Originally Posted by bunker
R U sure? I sent mail to streytl@sbcglobal.net.
Again, thanks for the help!
BTW, for those that are interested, I've discovered the reason for this problem of mine. With the help of another forum member, I found that there is a parameter for "Minimum BLM keep alive" and "Maximum BLM keep alive" that is only available in Tunercat. I loaded my Tunercat, with a more recent ecm deffinition file than I had previously been using, an lo and behold, they were set at 120 and 160 respectivly. I reviewed my bone stock file and it said 120 and 160 too. I checked a stock F body M6 file, and the settings were 128 and 160. So it seems that this is a quirk of the Y body program. I wonder why they did this?
Again, have fun. Also I believe it is all the tunes with Revision "C" that have it, I could be wrong but I found it on my REV "C" file, so if you have revision C instead of "E" then thats why.
I think the "C" also hits closed loop much sooner then "E" which takes like 3 mins to do it after start up aslong as temp parameters are met which "C" does it almost immediatelly. I could be wrong its what I noticed, also some AUTO tranny changes.
I have however seen it in a "e" flash come to think of it, but I believe Ed Wright tunes have the 120 thing going.
Nayr
Mar 3, 2023 08:34 PM
