Service Engine Soon - P0481
Old Sep 3, 2010 | 10:27 AM
NickkyCubba's Avatar
I own a 2001 Camaro Z28 and the SES light came on earlier today. Not waisting time I went to Autozone and had the codes read. P0481 Came up. I understand this is a cooling fan issue, but where should I start? What/where would be the best place to start testing to fix my problem? Any help is greatly appreciated!
Thanks,
NickkyCubba
Old Sep 3, 2010 | 10:12 PM
The GM code list indicates "SECONDARY COOLING FAN RELAY CONTROL CIRCUIT MALF". Check the relays for the fans. Swap them around, and see if the problem moves with the relay. If you move a bad relay from the secondary fan to the primary fan, the code would change to P0480.
Old Sep 4, 2010 | 06:56 AM
mudbone's Avatar
Fred,
Your advice is always golden! That is an excellent reply and a primer on troubleshooting.
cheapchevy
Apr 8, 2015 08:48 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Injuneer
Dec 15, 2014 09:36 AM
mspennyhughes
Nov 28, 2014 03:22 PM
transamtom
Aug 4, 2002 01:35 AM
