SD to MAF Conversion
Old Feb 2, 2011 | 10:02 PM
93redbird979's Avatar
Im looking into converting my SD 93 bird over to an OBD1 MAF system. anyone here done this or know whats involved. the only issue i forsee is that the 94-95 f bodies have the 4l60e while i have the 4l60. will this cause an issue or is it just a matter of not pinning for the transmission? will it throw a trouble code causing me problems engine wise? im pretty sure all that is needed is the 94-95 ecm, maf sensor, and maf harness. please correct me if im wrong.i want to be able to use tunercat or the likes for a street turbo build and this route(via salvage yard parts) is heaps cheaper than a standalone system.
Old Feb 3, 2011 | 10:59 AM
bobdec's Avatar
Re: SD to MAF Conversion
Responded to apost on this topic a week or so ago..I can list lots of problems, VSS feeds speedo directly in '93 but goes to PCM in '94 then to speedo. VSS signal is completely different between '93 and '94-'94. The '93 dash gauges (tac, speedometer) won't work w/'94 PCM signals. '93 EGR,TPS,air, knock sensor harness connections and operation all different between '93 and '94-'95. All problems can be solved , but it's not plug and play...
Old Feb 3, 2011 | 11:05 AM
Its looking more and more easier just to go standalone I guess. Guess you have to pay to play.
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
