? on scanning a 95 OBDII/OBDI
Old Dec 14, 2003 | 01:10 PM
Matt97PTA's Avatar
well i have a 95 with a OBDII connector but my hypertech will connect but cant scan it. I also have a laptop with LT1 edit for OBDII and some scan program but i know that the cable is locked to 2 vins(other than my 95) so i havent tried to scan it with that yet but since the cord is locked so i havent tried. I figure my car is a OBDI since im a sigle cat car an my scaneer wont read it but like i said its got the OBDII connector. what do i need to do to scan this?? any help is appreciated
Old Dec 14, 2003 | 05:35 PM
wicked_95z's Avatar
Firs thing is first. You are right about your car being and OBD-1. Second thing is your hypertech wont scan your computer unless you have the power scan cartridge. Thirdly, if you do have the OBD-2 version of LT1 edit it wont do you any good obviously cause you have an OBD-1 pcm. Also you can't use your hypertech cable with your laptop to scan the pcm because you need an interface between the laptop and the pcm also I dont believe the hypertech uses a standard serial port connector on the end of it. Not sure its been a while since I had mine.
Check out www.akmcables.com and Andrew will get you just the cable you need and then do a serach for either datamaster or freescan. Both are free dataloggin programs which you can scan DTC's with.
Old Dec 14, 2003 | 09:00 PM
Matt97PTA's Avatar
well i agree that hyper tech definily wont work with my computer, but i actually have 2 other vehicles a a 96Z and 97TA that i have used LT1 edit on but obviously those are OBDII and i know the cable is locked since i dont have the pro version so i was thinken maybee i could by pass that or something but illl email that guy and find out.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
jayblev95
Sep 26, 2015 09:44 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
