Rough Startup '88 IROC
Old Aug 31, 2004 | 09:20 PM
Pdiminico's Avatar
Ok, A1 is not lighting up when I put the test light direct to A1 on the ECM. when I turn the key to the "run" position, the test light never lights up. Is it possible that this is the only ECM pin that would fail?
Ok, so if I install a switch that would feed 12 volts from the orange wire to the green/white wire on the relay that should allow the fuel pump to run until the car Starts.
Any thoughts?
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
