Reseting BLM's after programming for SVO's.
Old Sep 2, 2002 | 02:12 PM
CanadianZ's Avatar
Post Reseting BLM's after programming for SVO's.
I just reprogrammed my PCM for my 24# SVO's and I wanted to know how to reset the BLM cells in the PCM. I am assuming I was running rich as the car wasn't programmed for the last year with the SVO's in there so the BLM cells will probably be way off now that the injector size is set correctly.
Can you just pull the PCM fuse for 30 seconds?? If so, where is it?? Thanks.
CanadianZ
Old Sep 2, 2002 | 07:42 PM
gb95zconv's Avatar
Post
Once you flash the pcm it is reset. Just run the engine under various load conditions for a while to give the BLMs a chance to learn.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Sep 2, 2002 | 09:21 PM
CanadianZ's Avatar
Post
Thanks for the reply. I guess I don't have to reset the PCM.
CanadianZ
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
surreybrad
Jul 29, 2015 02:55 PM
