Replace N/B o2's with output from wideband
Can it be done? I plan on buying a LC-1 w/b for tuning and placing it in the turbo downpipe. I do not want to buy two stock o2's if I could use the simulated output of the LC-1. I searched other posts and see that the heater circuit may be a problem unless it is programmed out. Looks like I would have to tie the pcm inputs together and feed the LC-1 n/b output to them. I already have the bungs welded into my turbo crossover for the stock n/b o2's, so i could easily spend the $80 and thread them in.....but Id rather spend the $80 towards the LC-1 that I will be buying anyway.
When I removed the stock o2's from my stock exhaust I ruined the treads due to rust. So its...Buy new ones or basterdize with the LC-1??
