Reading plugs to tune WOT
Old Jul 22, 2003 | 03:14 PM
  #16
96speed's Avatar
Originally posted by rskrause
Ryan: obviously, the injectors can't be open more than 100% of the time. But if the PCM is commanding a >100% duty cycle, there's a problem. You can't even tell if the injectors are appropriately sized, because most injectors will not operate reliably at >80-85% duty cycle. This is not just "urban legend". I have seen it, many times. You need to get the duty cycle down to the 80% range and see if it's rich or lean. If it's rich, back off the PE v. load v. rpm. If lean you can either raise the fuel pressure or go to larger injectors.
Rich Krause
Hey Rich. I sent you an email last night that had some baseline times/mph and some info. Did you receive it?
Ryan
Old Jul 22, 2003 | 05:53 PM
  #17
rskrause's Avatar
Moderator
Ryan
I'll look for it again, but I don't recall seeing it. Can you re-send?
Rich Krause
Old Jul 22, 2003 | 06:37 PM
  #18
96speed's Avatar
Smile
Sent..thanks.
DirtyDaveW
Dec 1, 2016 05:37 PM
jayblev95
Jan 20, 2015 01:30 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
