quick handheld question.....
Old May 1, 2007 | 08:00 PM
Z28luvr's Avatar
Can the temperature at which the cooling fan comes on be adjusted with a handheld? I'm asking because I'm looking to install a cooler t-stat......and also wanting to do a couple of other pcm mods........
Old May 1, 2007 | 09:30 PM
2000GTP's Avatar
Not sure which handheld you are referring too but the Hypertech ones do have the feature that allows cooling fan on/off adjustments.
Old May 2, 2007 | 04:27 PM
Z28luvr's Avatar
Originally Posted by 2000GTP
.....Hypertech ones do have the feature that allows cooling fan on/off adjustments.
any others?
Old May 2, 2007 | 06:28 PM
2001NBMZ28's Avatar
If you're thinking handheld only, Predator will do that at 1 degree increments, plus a whole lot more.
Old May 3, 2007 | 11:17 AM
VinceTrifecta's Avatar
Traditional handhelds (Hypertech, DiabloSport, Superchips, etc) typically only work optimally with completely stock vehicles. If you've done so much as added a cold air-intake or installed a K&N filter, there's a chance your WOT AFR will be off. I'm probably biased :-) but custom PCM tuning typically yields better results and it is cheaper then buying a handheld that you'll probably only use once.
When you order custom PCM tuning, you simply tell them what you've done and they make the program right for your vehicle.
Old May 4, 2007 | 07:40 PM
Z28luvr's Avatar
That's REALLY good advice.....will take that into consideration......
question.....if I run a 160 stat, do I set the cooling to come on at 160? what temp to go off?
one more question....should I get rid of that damn annoying spark knock my engine has before I tune the pcm?
Old May 5, 2007 | 12:42 PM
2001NBMZ28's Avatar
You have low speed fans and high speed fans. I have a 160 and have mine set at - on 184/off 175 (low) and on 194/off 185 (high).
Old May 5, 2007 | 04:20 PM
Z28luvr's Avatar
^do those settings work for every car that has a 160?
Old May 5, 2007 | 04:57 PM
2001NBMZ28's Avatar
That's what was recommended to me by James at RWTD a few years ago - in summer my high speed runs alot, but I have most of the radiator blocked by the FTRA and live in a warm climate too. My '01 owners manual says the car came with a 180, so another option is don't get a 160 and just adjust the fan on/off temps. Here's a chart RWTD has posted, think it's the same hypertech used too, use as a starting point.
Stock
Fan 1 on/off: 209/200
Fan 2 on/occ: 219/210
180
Fan 1 on/off: 194/185
Fan 2 on/off: 204/195
160
Fan 1 on/off: 184/175
Fan 2 on/off: 194/185
If you set the low or high fans to come on at 160 they'll probably run 100% of the time after warmed up. Stock settings are much higher.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
