Programming for different tire sizes?
Re: Programming for different tire sizes?
Originally Posted by 1SlowFormula
NO WAY... If you change tire size and have it programmed for a different tire the MPH read by the computer will be off...
Originally Posted by steve9899
And if you don't touch the programming, both parameters (MPH and RPM) will be met at the exact same RPM as before.
If it's not intuitive to you, then either (a) do the calculations of speedometer conversion and shift mph conversion so you can see that the net effect is nil or (b) simply put the tires on and see for yourself that it shifts at the same place.
Wow. I just looked at your profile - you are a computer programmer and you can't see this?
Hence why you said not changing the tune... The reason I wasn't thinking about that is because I will be doing the rear and tires at the same time and was going to have to retune anyway and was thinking about tuning for the bigger tire from the start and that is why the issue stuck in my head...
Why would you need to worry about any of this? Program the mph lower than when you'd want to shift to occur, that way the pcm uses the rpm to know when to shift.
You really don't want to trust your VSS after a nice hard launch on an A4, do you?
I know this is an old thread, but would this work? Have the computer programmed to shift at a lower speed than needed, and have it shift on RPM instead of speed? I'm confused how something like this would work.
kizz
Jul 6, 2002 11:03 AM
