Problem reading PCM
Old Aug 21, 2002 | 05:12 PM
bad95z28's Avatar
Post Problem reading PCM
I have tried to read my PCM twice now w/ Flash. I have the Tunercat windows version. I am new to this programming so I may be doing something wrong. The first time it went over 50% and the second time it only went about 30%. Anyone have any idea what would be causing this?
Thanks, Michael
Old Aug 21, 2002 | 05:36 PM
Hal Fisher's Avatar
Post
Do you have a screen saver, time out on your hard drive, or anything trying to go into power saving mode? Shoot TC a message about this problem.
Hal
Old Aug 21, 2002 | 05:52 PM
bad95z28's Avatar
Post
Hal,
I think the first time was due to my screen saver coming on. I set it to 20 minutes and set the hard drive to 20 minutes because I thought that may have been the cause. But, I'm not sure why I failed on the second read. I may try it again here in a little while but I had one question. I've had to reset the PCM both times now. There is no way that I can damage my PCM just by reading it is there?
Black 94Z A4 t-tops
324rwhp/316rwtq (before new mods and better tuning)
The Z
Old Aug 21, 2002 | 06:43 PM
Hal Fisher's Avatar
Post
Supposedly there is no way to harm it when reading. The big diffence is when your writing you flash it first to earse and thats where the harm is.
Hal
Old Aug 21, 2002 | 07:41 PM
NONO5.0's Avatar
Post
Are you using the 'flshprog' and 'flshread' programs? If so, for best results, you should do this thru a true DOS mode. Hope this helps
Owner of the slowest LT1 ever made. No, really! I think they made the workers come in on Christmas day to finish my car.
Old Aug 21, 2002 | 08:13 PM
bad95z28's Avatar
Post
I'm trying to use the Windows version of Tunercat. Now I am getting an error that says cable failure.
Black 94Z A4 t-tops
The Z
Old Aug 21, 2002 | 11:23 PM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Post
Is there any power acc on when you are doing this? Also are you running of the battery of the laptop or are you pluged in? Also if you are pluged in, is it to through a power converter off the car. Make sure when you are reading or writing that the Laptop is pluged into the car, Make sure that there are no other programs running in the background(little icons in the bottom right corner near the clock) and NOTHING is turned on in the car. Also what OS (windows 98, windows 2000, windows ME) are you running. If you have 98 there are definitly programs running in the back ground! If you are useing 2000 you should be alright, if you are running ME -good luck you'll need it!
Old Aug 23, 2002 | 04:48 PM
Dr.Mudge's Avatar
Post
Andrew has said that there is no way to damage when reading, which is perfectly sensible.
If you are using a power converter I have had one that resets power after about a minute and interupted communications, very nerve wracking, it let out a BEEP and cut power for a millisecond (or whatever, laptop remained on but it did interupt my read).
Move your mouse around once a minute or so if you wish. Also, I unplug the fan relays before I read/write to save battery. If your getting cable failure either the connection to it is bad (obviously), or perhaps in Windows something is interfering, you are using the serial port not USB right? If you have Infrared port, disable it, etc etc
Old Aug 23, 2002 | 04:57 PM
Hal Fisher's Avatar
Post
Turn the laptop on and bring up the flash program but don't do anything. Just left is sit for 10 minutes and see if some power saver comes on. Some laptops have power saving controls in the system bios. If it fails bring up the bios and look for some kind of power saver still on.
Hal
Old Aug 23, 2002 | 06:45 PM
bad95z28's Avatar
Post
I think that my problem was a combination of things. I thing the infrared port, Palm Pilot software, and a few other things may have been causing it. I haven't had a chance to try it again but has anyone ran Tunercat w/ Windows ME succesfully?
Black 94Z A4 t-tops
The Z
Old Aug 23, 2002 | 10:15 PM
97 RedSS's Avatar
Post
Argh...I cant get my new Dell Laptop to communicate with my PCM..Sometimes it does and others it wont...Using freescan it whilel read the parameters for a few secs then stop,then read,then stop..Not sure what is going on at all..Ive I Flshread my PCM it will make the file but the file will NOT contain anything..Has 0kb of info when it saves it..
Anyone have any suggestions?
Im running WinXP
Cody
97 30th Anniv Camaro SS#2374~ Forged 383 w/4 bolt mains,Pro5.0,LT4KM,Pro Performance Heads(288in/216ex@.600"),GTP-6 cam,Comp. Magnum 1.6" RR's,Chromoley Pushrods,Edelbrock Double Roller,Meziere,52MM BBK TB,Hooker LT's w/ Custom 3" Y-pipe,Borla,SLP CAI,30# Inj.,OBD1PCM,SPEC Stage 3 Carbon
Old Setup Dyno #'s on Stock Bottem-End NA~ 370rwhp/353rwtq
My SS
E.T.F.A East Texas F-Body Assoc.
-Kiss my SS-
Old Aug 24, 2002 | 01:18 AM
Dr.Mudge's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by bad95z28:
</font>
Yes, using a Win9x boot disk. Palm stuff is loaded in Windows, so that shouldn't be a problem, IR should be disabled in CMOS setup at bootup, DEL, F1, F2, are usually how you get in, but many laptops use exotic key combinations to get into CMOS to avoid people mucking it up on thier own by hitting just a single key.
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Mar 13, 2015 09:39 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
