Predator tuning help. What temp to set cooling fans with 160 degree T-stat?
Old Jun 30, 2004 | 01:05 AM
Schantin's Avatar
I just got a Predator tuner and a 160 degree Hypertech T-stat in the mail. I am going to install the thermostat to reduce the freaking high temp the car is running at (195 cruise, 230 traffic.)
Anyhow, what temps are recommended for turning on and off the electric cooling fans? I'm shooting for a sustained temp in the 180-185 range.
Also, how good is the Diablo tune? I had a HPPIII+ on my old LT1 Camaro. I neer used their performance tune, just reset the cooling fans and compensated or gears. It seems that I HAVE to install the power tune with the Diablo to change fan temperatures, etc.
Will the lower coolant temp adversely affect the tune/ car? Also, I can only get 92 octane gas here. Any big problems with that?
I appreciate all the help that I can get. I listed my mods to help answer my tuning questions. Thanks in advance!
Schantin
2002 Camaro Z28 M6
Mods: Flowmaster 3" cat-back, QMP airlid, K&N filter, Pro 5.0, AutoMeter A/F and H2O gauges, AMW catchcan (next weekend ), 18x9.5 ZO6 wheels/Kumho tires.
Old Jun 30, 2004 | 04:52 PM
sabre81's Avatar
i recommend turning the low speed fan on at about 192 deg and the high speed on at 195 deg. You dont want that engine operating too cool.
Old Jul 1, 2004 | 11:03 PM
Schantin's Avatar
Thanks for the info !
Schantin
2002 Camaro Z28 M6
Old Jul 6, 2004 | 02:35 PM
rckrzy1's Avatar
I set mine for 170 and 180
Old Jul 6, 2004 | 02:51 PM
sabre81's Avatar
wow thats quite low. I bet your gas mileage would increase and maybe even increase throttle response a bit if you let your engine run a bit hotter. These were my results. I would go no lower then 180 for low speed fan.
Old Jul 6, 2004 | 11:00 PM
rckrzy1's Avatar
Perhaps things are different so far North of the mason
dixon line. Heat is a killer of power down here. And with
a/c on and 75 mph I get 26 mpg in 6th gear.
SLIMJIM
Jan 7, 2003 11:06 AM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
