power programmer plus or 3
Old Dec 23, 2005 | 06:51 AM
  #16
Z28_95RIDE's Avatar
Re: power programmer plus or 3
Originally Posted by DOOM Master
You aren't the only one with first hand experience with the units either. Hate to break it to you, but how do you think I got the copies of the PCM calibration files for the HPP? I really don't care if you buy Hypertech or not it's your money to waste. But the simple fact is, their units are overpriced, overhyped by the company, and you are not an objective witness at all. I have over 4 years worth of tuning experience with LT1s as well as various other GM V8s. I've been down this road before.
I'm objective because I'm not making false and inaccurate statements and don't have an obvious contempt for Hypertech or any other tuner. Your 4 years worth of tuning experience tells me nothing, especially after going over your errors. Simply, your claims aren't verifiable. If I am able to post the VE and timing tables it will be my last post in this thread and it won't be for you.
Old Dec 23, 2005 | 11:06 AM
  #17
DOOM Master's Avatar
No, you aren't objective, what you are doing is attempting to make the money you threw away on Hypertech seem like a good buy. That's not objective. I was objective about Hypertech before I had a chance to go over their calibration files and find that they don't actually change anything other than a few simple things. You seem to be really big on this whole "I'm not biased issue because..." Well, guess what again? You can be objective but still come to a conclusion that is biased against another's conclusion.
You conclusion that Hypertech is a worthwhile product is based on your view that you could feel the difference. No other data to back up your claims, only that you can feel the difference. This is anecdotal evidence, and it's useless.
My conclusion is based on actually working with these vehicles, doing the tuning, comparing the calibration files, AND seeing the results on a dyno first hand. And I'm not the only one, you can ask just about anyone else that has been into these cars and their PCMs for the past 5 years, and you'll get the exact same results.
I'll be posting the comparisons between my stock 94 Z28 calibration file and the HPP+ calibration file for a 94 Z28 later on.
Old Dec 23, 2005 | 11:14 AM
  #18
Spark Advance tables
Here are the spart advance tables for the stock 94 Camaro Z28 LT1, 4000+
35.0 41.0 43.0 44.0 43.0 42.0 41.0 41.0 39.0 39.0 38.0 38.0 37.0 35.0 35.0 33.0
35.0 41.0 44.0 44.0 43.0 42.0 41.0 40.0 40.0 40.0 39.0 38.0 37.0 35.0 35.0 33.0
35.0 41.0 44.0 44.0 43.0 42.0 41.0 40.0 39.0 39.0 39.0 38.0 37.0 35.0 35.0 33.0
35.0 40.0 44.0 44.0 43.0 42.0 41.0 40.0 39.0 39.0 39.0 38.0 37.0 35.0 35.0 33.0
35.0 40.0 44.0 44.0 43.0 42.0 41.0 41.0 40.0 40.0 39.0 38.0 37.0 35.0 35.0 33.0
35.0 40.0 44.0 44.0 43.0 42.0 41.0 41.0 41.0 41.0 39.0 38.0 37.0 36.0 36.0 36.0
35.0 40.0 44.0 44.0 43.0 42.0 41.0 41.0 41.0 41.0 41.0 41.0 40.0 38.0 38.0 38.0
Here are the tables for the HPP+ 94 LT1 Camaro Z28, 4000+
The look exactly the same to me
Edited to add 4000+ to the end of the HPP portion
Old Dec 23, 2005 | 11:18 AM
  #19
Volumetric Efficiency Tables
Here are the stock VE Main tables for a 94 Camaro Z28 LT1
48.4 52.7 55.1 56.6 58.2 60.2 62.1 64.1 66.0 67.6 68.8 69.9 70.3 71.1 71.9 73.4 74.6
50.8 54.7 57.4 59.4 62.1 64.1 65.6 67.6 69.5 70.3 71.1 71.9 72.7 73.4 74.2 75.0 76.2
51.6 56.3 58.6 61.3 64.1 66.0 68.0 69.1 70.3 71.1 72.3 73.0 74.2 75.4 76.6 77.3 78.5
53.1 57.8 61.3 64.5 66.4 68.0 69.5 71.5 72.7 74.2 75.0 76.2 77.0 78.1 78.9 79.3 80.1
55.9 60.5 63.3 66.4 68.8 70.7 72.3 73.0 74.2 75.0 75.8 77.0 78.1 78.9 79.7 80.1 80.9
58.6 62.5 66.0 68.0 70.7 71.9 73.8 74.6 75.8 77.0 78.1 78.5 78.9 79.3 79.7 80.5 81.3
60.5 65.6 68.0 70.3 71.9 73.0 74.2 75.8 77.0 77.7 78.5 78.9 79.3 79.7 80.1 80.9 81.6
62.5 67.2 69.5 71.5 73.4 74.6 75.8 77.0 77.7 78.5 78.9 79.3 79.7 80.1 80.5 81.3 82.0
64.1 68.8 71.1 73.4 75.0 76.2 77.0 78.1 78.9 79.3 79.7 79.7 80.1 80.5 80.9 81.6 82.8
Here are the VE Main tables for the HPP+ 94 Camaro Z28 LT1
Again, exactly the same.
Old Dec 23, 2005 | 11:20 AM
  #20
VE tables extended
Here are the VE extended tables for the stock 94 Camaro Z28 LT1
64.8 69.5 71.9 73.8 75.8 77.0 77.3 78.5 79.3 79.7 80.1 80.5 80.9 81.3 81.6 82.0 83.2
65.6 70.3 72.7 74.6 76.6 77.7 78.1 78.9 79.7 80.1 80.5 80.9 81.3 82.0 82.4 83.2 84.0
66.0 70.7 73.0 75.0 77.0 78.1 78.5 78.9 79.7 80.5 80.5 81.3 81.3 82.0 82.4 83.2 84.4
66.4 71.1 73.4 75.4 77.3 78.5 78.9 79.3 80.1 80.5 80.9 81.3 81.6 82.0 82.4 83.2 84.4
66.8 71.5 73.8 75.8 77.7 78.9 79.3 79.7 80.5 80.9 81.3 81.6 82.0 82.4 82.8 83.6 84.8
67.2 71.9 74.2 76.2 78.1 79.3 79.7 80.1 80.9 81.3 81.6 82.0 82.4 82.8 83.2 84.0 85.2
67.6 72.3 74.6 76.6 78.5 79.7 79.7 80.5 81.3 81.3 82.0 82.0 82.8 83.6 83.6 84.4 85.9
68.0 72.7 75.0 77.0 78.9 79.7 80.1 80.5 81.3 81.6 82.0 82.4 83.2 84.0 84.4 85.2 86.7
68.8 73.0 75.4 77.3 79.3 80.1 80.5 81.3 82.0 82.4 82.8 83.6 84.4 85.2 85.9 86.7 88.3
69.5 73.4 75.8 77.7 79.7 80.5 81.3 82.0 82.8 83.2 83.6 84.4 85.2 85.9 87.1 88.3 89.8
70.7 75.0 77.0 78.9 80.5 80.9 81.6 82.8 84.0 84.8 85.9 86.7 87.5 88.3 89.1 90.2 91.8
71.1 75.4 77.3 79.3 80.9 81.3 82.0 83.2 84.4 85.2 86.3 87.1 87.9 88.7 89.5 90.6 92.2
Here are the VE extended tables for HPP+ 94 Camaro Z28 LT1
No changes, again
Last edited by DOOM Master; Dec 23, 2005 at 11:22 AM. Reason: forgot to add text for HPP+
Old Dec 23, 2005 | 11:27 AM
  #21
Open loop tables
Here are the Open Loop vs Coolant Temp vs MAP tables for the 94 Camaro Z28 LT1
8.0 8.0 8.0 8.0 7.9 7.8 7.8 7.8 7.7 7.6 7.6 7.6 7.5 7.5 7.5 7.5 7.5
8.8 8.8 8.7 8.6 8.5 8.4 8.4 8.3 8.3 8.2 8.1 8.1 8.1 8.1 8.1 8.1 8.1
10.1 10.1 10.1 10.1 10.0 9.9 9.7 9.6 9.5 9.4 9.3 9.3 9.2 9.2 9.2 9.2 9.2
10.9 10.9 10.9 10.9 10.9 10.8 10.6 10.5 10.5 10.4 10.2 10.1 10.0 10.0 10.0 10.0 10.0
11.5 11.5 11.5 11.5 11.4 11.3 11.0 10.9 10.7 10.6 10.4 10.3 10.3 10.3 10.3 10.3 10.3
13.6 13.6 13.6 13.6 13.4 13.2 13.1 13.0 12.9 12.8 12.6 11.8 11.0 11.0 11.0 11.0 11.0
13.9 13.9 13.9 13.9 13.8 13.7 13.4 13.3 13.2 13.0 12.8 12.2 11.3 11.3 11.3 11.3 11.3
14.2 14.2 14.2 14.2 14.2 14.0 13.8 13.7 13.5 13.4 13.1 13.0 11.7 11.7 11.7 11.7 11.7
14.3 14.3 14.3 14.3 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 13.1 12.0 12.0 12.0
14.3 14.3 14.3 14.3 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 13.3 12.4 12.4 12.4
14.3 14.3 14.3 14.3 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 12.8 12.8 12.8
14.3 14.3 14.3 14.3 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 14.2 12.9 12.9 12.9
14.3 14.3 14.3 14.3 14.2 14.0 13.8 13.7 13.5 13.4 13.1 13.0 12.9 12.9 12.9 12.9 12.9
Here are the Open Loop vs Coolant Temp vs MAP for the HPP 94 Camaro Z28 LT1
Even for Open Loop operation, there is still no changes
Old Dec 23, 2005 | 11:34 AM
  #22
At this point, I think it's obvious
As anyone can plainly see, there are no changes in 4 of the very important tables for power production on the LT1. I could go through every single table and post the results here, but I really don't have to.
So, still think HPP changes the timing tables for WOT operation? And just what errors might you be talking about that I made. Those tables are exactly what I said they were. Z28_95RIDE, the errors are yours for actually thinking Hypertech did something.
If anyone wants a copy of these files, I'll be happy to send them
Dec 1, 2014 08:08 AM
SLIMJIM
Jan 7, 2003 11:06 AM
XtremeLt1
Sep 13, 2002 08:50 PM
naaz90
Jul 27, 2002 08:22 AM
