Is it possible to edit my vehicle using a cable that worked for my thirdgen?
Old Jan 16, 2004 | 02:22 AM
Pasky's Avatar
I have a cable that works on my 91 RS that I used for diagnostic software, but now I have a 95 Trans am LT1 and T-56 sitting in my garage that is about to be implanted into it along with a 95 PCM. My question is can I use my old cable with the new PCM and use tunercat to tune my vehicle? Thanks.
Old Jan 18, 2004 | 07:36 PM
LWM's Avatar
LWM
Risk an $800 PCM
Buy a new cable ... $50
Not sure about you, but I'd spend the $50
Hope that helps
LWM
Old Jan 19, 2004 | 12:16 AM
DOOM Master's Avatar
Originally posted by LWM
Risk an $800 PCM
Hope that helps
LWM
Sorry, but I fail to understand the risk? There is no risk. The cable will work. The cable will work on any OBD1 PCM from GM, years 85-95. The only question you will have is whether or not it will work with the software you plan on running. It should, but it might not. Some cables are software specific, unforunately.
Old Jan 19, 2004 | 05:10 AM
SABLT194's Avatar
Like Doom says
I use my LT1 cable for 3rd gens all the time. Works for GM trucks, syclones, yada,yada,yada.
Steve
Old Jan 19, 2004 | 07:07 PM
Pasky's Avatar
Ok great. Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Bando
Aug 2, 2002 02:18 PM
