Please HELP!! PCM Tuning Problem
Old May 21, 2004 | 03:11 PM
95_Blk_Z28's Avatar
I recently bought a cable from AKMCABLES.com for a 1995 z28 Camaro. I then purchased a programming package from Bryan at PCMFORLESS.com. Today I went and tried to run the program and everytime it was trying to establish communications with the pcm I got an error that said, "Invalid Response From PCM." I was just wondering If anyone has any ideas on what this could be. I'm using a USB to Serial adapter, but I installed the drivers for it and my labtop recongizes the adapter on COM1. I'm hoping this isn't the problem because the stupid adapter was $30 from Best Buy, but who knows. Next, I tried to test my communications by using the DataMaster program I downloaded from the link AKMCABLES.com provided. After I setup the COM port I clicked "Test Com" and a message displayed saying something like this, "ALDL is working, but recieved undectable data. This PCM Type may not be recognized." I was just curious if anyone at all had any suggestions of what this could be; whether it's a problem with my PCM, my adapter, my cable or whatever else it could be. Please let me know if you have any thoughts. Thanks!
Old May 21, 2004 | 03:36 PM
ram air camaro's Avatar
CALL BRYAN.
Old May 21, 2004 | 05:01 PM
Brent94Z's Avatar
Super Moderator
The problem is most likely your USB to serial adapter. I have heard those can be hit or miss. Can you take your desktop out to the garage, set it on a table, and try it? Might want to try that. I also believe better luck is had with a card adapter to serial port rather than USB to serial.
Old May 22, 2004 | 07:30 AM
95_Blk_Z28's Avatar
Thank you! I think it's the adapter as well. I have a buddy that has a labtop with a serial port on it. I'm going to try his this weekend to see what happens.
Old May 23, 2004 | 05:08 PM
Greg_pl's Avatar
If it's only a problem with an USB adapter (test with your friend's laptop or with a desktop, like Brent said) you can buy PCMCIA serial port card from ebay (about $40ish), they do work with no problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
Bignasty85
Mar 3, 2015 04:05 PM
nikolt1
Feb 27, 2015 09:10 PM
97SSdude
Dec 31, 2014 07:43 PM
turbo_Z
Aug 19, 2002 10:50 PM
