PE tuning for 1228746/L03
Which table or tables need to be modified to tune for P.E. with a 1228746 ecm / L03 engine? I'm using Tunercat.
I've already worked out the part throttle fuel map and the ignition map, but I now need to work on the P.E. and I'm not sure where to tweek.
Your best bet for a answer is to check out www.thirdgen.org and go to the TBI and or the DIY-Prom forums.
Aug 24, 2015 06:41 AM
