PE Idle Help!!!
Old Dec 15, 2005 | 10:52 PM
  #16
Slow260z's Avatar
Re: PE Idle Help!!!
Negative pressure is a vacuum. Two additional things I saw were: on my datamaster you continually had data errors and LOW voltage. Also you have knock which I would wait until vacuum leaks are solved before worrying about. I would definately fix the voltage since LT1's like >14 volts in my limited experience.
Good luck
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
