Which PCMCIA to Serial Adapter Card Works?
Old Aug 7, 2009 | 08:20 PM
  #16
Hal Fisher's Avatar
I haven't tried the keyspan since I know my other one works.
Hal
Old Aug 8, 2009 | 01:51 AM
  #17
Hal Fisher's Avatar
bricked my first pcm
Didn't mean to not answer you. Yes, I installed the virtual drivers. Should I have? If I should what port should they be set for? I mean com setting is a tricky thing. Com1 and 3, and 2 and 4, share IRQs.
I did brick the pcm today. I was actually using the Keyspan and it blue screened in Xp. The error was something like serial port divide by zero error. I'm sending it off to AKM and getting it socked. For around $50 he does the socket, gives a few extra flash proms, and ships it back, that's a deal!
I would have bought a cheap laptop that has a serial port but you always have to buy a good battery as well because old laptops never come with a battery that holds a charge.
Hal
Originally Posted by MikeGyver
Did you install their virtual com port drivers? Does it do it EVERY time you go WOT? or do you just have a loose wire lol
Old Oct 17, 2010 | 12:07 AM
  #18
Magneto's Avatar
serial PCMCIA
I have tried several models of serial pcmcia cards and USB serial adapters and been able to conclude that if you are getting a good quality adapter / card then it will work fine with Windows 7 32 and 64 bit , however if you are getting a cheap $9 adapter then its useless. I found mine at www.usconverters.com. Highly recommended. </p>
DirtyDaveW
Dec 1, 2016 05:37 PM
nosliw
Feb 7, 2015 01:30 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Paulberg
Jul 26, 2002 11:35 AM
