pcm harness wiring
Old Aug 3, 2008 | 01:57 AM
bowtiekid's Avatar
Exclamation pcm harness wiring
Ok so I'm wondering what gauge of wiring the pcm harness uses for injectors, IAC, oil level sensor, and VSS. Or even all the sensors would be great if anyone has a chart. But The sensors listed above on my car the wiring is all decayed at the sensor connection. and I would like to repair it all without buying a pigtail cuz I'm not bad at soldering. Just need to know what the gauge is because I went and bought an automotive 22ga wire and it was even too big so need some advice. I'm pretty positive that the reason you need the same gauge is so that there isn't aresistance change to hinder pcm readouts correct? Is radioshack where I should go for the wiring?
And I ordered a painless warning light to run all the time with my ewp so I know the pump is working. Will an 18ga. Wire work for the light? Its running from the relay all the way beside my a/c controls in my dash.
Thanks in advance.
-Mark
Old Aug 3, 2008 | 10:14 AM
bowtiekid's Avatar
Anyone???
Up
Old Aug 3, 2008 | 08:02 PM
No need to post the same question on multiple forums.
https://www.camaroz28.com/forums/sho...d.php?t=625225
willismoons
Feb 14, 2015 08:42 PM
jayvar
Feb 2, 2015 10:00 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
