pcm bad?
Old May 31, 2005 | 07:58 PM
blackz151's Avatar
pcm bad?
i got a 96 z28 the guy i bought it from put a obd1 in it. now i burn the left 02 up evey 3 months. and now i have it unpluged it takes about 20 mins for it to put out a SES light. is that normal? i figured it should put the light on right when it starts. if any one could help it would make this problem mutch easyer to solve
Old Jun 1, 2005 | 12:44 AM
SteveZ Z-28's Avatar
Re: pcm bad?
If I remember correctly, if the O2 sensor is not working properly, the computer will not notice until it reaches closed loop, which usually takes a few minutes. If the SES light consistently comes on after 20 minutes or so, I would guess it is more something emissions regulation related, like the EGR system is not working properly. Although it could be because the O2 is disconnected. You should get the car scanned to see what code you are throwing. It's hard to diagnose until you know that.
Have no idea why you are wasting O2 sensors. Which ones do you buy? I know that most people have better luck with the AC Delco O2 sensors. I believe the part number is AFS75 for the fronts.
Old Jun 1, 2005 | 08:04 AM
blackz151's Avatar
Re: pcm bad?
the code is LEFT O2 FAIL and when the go bad the code i get is LEft o2 Lean
i use the ac delco ones from gm. And it only the left side not the right
so i was hopeing the computer was frying them or somthing cuz its pi$$in me off a lil bit. I have like 12 o2 packages at the house snice i owned the car. it starting to get a little $$.
TitoPR221
May 26, 2015 12:20 AM
Zuvell
May 15, 2015 08:18 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
