p4030
Old Mar 12, 2012 | 10:22 PM
edgarda2's Avatar
p4030
is anybody familiar with this code???????? on their camaro??
Old Mar 12, 2012 | 11:43 PM
Re: p4030
I suspect you meant to type P0430?
P0430 = BANK 2 Catalytic convertor low oxygen storage. The PCM looked at the passenger side after-cat O2 sensor and didn't see the range of O2 values it expect to see, and interpreted that as a bad cat. If you have a cat, it could be the cat, could be the O2 sensor or could be the wiring. Clear the code, swap the two after-cat O2 sensors and see if the code stays on the passenger side (P0430) = faulty cat, or follows the O2 sensor to the drivers side (P0420) = faulty O2 sensor.
And since this isn't a "Wheels and Tire" topic, let's movie it to "Computer......."
