p1406 code help
Old Oct 21, 2008 | 09:33 PM
mccauls_ss_camaro's Avatar
p1406 code help
what dose this code mean beside's manufactuer control auxiliary emission control? 96 rs 3.8l
Old Oct 21, 2008 | 10:58 PM
Green96Z's Avatar
P1406 is for the EGR valve. Try pulling it off and cleaning it out. If that doesn't work you might have to replace it.
Old Oct 22, 2008 | 01:25 AM
ok is there any type of cleaner that is safe to use on the egr? carb/brake cleaner fine?
Old Oct 22, 2008 | 01:41 PM
ok i got it off and now i cant get it apart is there a trick to this?
Old Oct 22, 2008 | 11:07 PM
code hasnt came back after i cleared it and i didnt see any build up in it
Old Oct 23, 2008 | 09:46 PM
anyone got a walkthough on cleaning the egr i can get it off but idk how to tear it apart i dont want to break it
Old Nov 26, 2008 | 11:03 PM
i blocked it off helped a lil
Old Nov 27, 2008 | 09:30 AM
bobdec's Avatar
There is a EGR valve position sensor involved here. Either the valve is not moving properly (carbon buildup at the open/close tip) , the position sensor circuit is faulty, or the wiring to the EGR valve solenoid or sensor is defective. Cleaning usually helps , but it could also be other causes.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
