P0403,p0443
Old Jan 21, 2012 | 10:08 PM
soulassassin's Avatar
Talking P0403,p0443
I am a recent and first time owner of a 97 z28. I am getting a P0403 & P0443 codes. I know they are EGR & EVAP faults. I have checked and changed any vacuum lines I feel to be suspect. I have replaced EGR VACUUM SOLENOID and EVAP CANISTER PURGE SOLENOID VALVE. I not sure if im just being extra paranoid but I get a wiff of gas fumes now and then.. Any input from you pros would be great!!!! STILL GETTING THESE CODES!!! When i start moding i hope to get these emission stuff tuned out.
Old Jan 22, 2012 | 08:31 AM
Re: P0403,p0443
Both codes are specifically for the electrical circuits to the solenoids. The code can not be set by problems with any other part of the system like the vacuum lines, canister, EGR valve, etc.
After you replaced the solenoids, did you clear the codes (pull "PCM BAT" fuse for 30 seconds).
Did you check the fuse for the solenoids?
Old Jan 22, 2012 | 02:38 PM
Re: P0403,p0443
I tried to reset onlyby disconnecting the negative battery terminal. Is there another way? Is the fuse located in the compartment under the Hood or in the car under the dash?
AFK9
Feb 16, 2010 09:11 PM
mvnatedog
Jan 16, 2008 01:31 PM
camaroLevi
V6 Tech
Dec 21, 2007 03:25 PM
El Eve
Jul 31, 2007 04:34 PM
moparman
Feb 4, 2007 05:20 AM
