Open Vs Close Loop
OK, forst of all turn capslockk off.
Second of all, this isnt an advanced tech question, but since i cant move it, I will answer it....
Closed loop is a term for when your cars computer is changing the air / fuel mixture and keeping it at 14.7 to 1.
In order to reach closed loop your car has to be warmed up. about 180 probibly.
Open loop just means you car isnt in closed loop. You O2 sensors are still giving readings to the computer, but the computer isnt changing anything.
Somtimes it feels like the car is a little stronger in open loop because you are running a little richer, but not much. and only at part throttle. As soon as you go to wide open throttle it drops the air fuel raito to about 13:1 anyway. So, it effectively goes into open loop at wide open throttle every time. Since your fuel economy is better in closed loop and power should be about the same, thats where your car will usually run. There are ways to make the car stay in open loop ( I think pulling the air pump fuse will do it) but there is no reason to, you will just wear out your cat (s) really fast and get worse gas milage.
FYI
Different air fuel raitos are better for different things.
about 17:1 is actually the best for fuel economy but on a high powered engine like ours it would pre-ignite at that raito. Only some of the new hybrids actually run at super high raitos like that.
14.7:1 to one is the best for emissions its also a pretty good balance for fuel economy and power.
12.7-13.1:1 is best for power, it varies a little from motor to motor.
FYI
As Dave pointed out, this post belongs in "Computer Programming....." forum, and I will move it there.
Additionally, some of what is in Dave's response is not quite correct.....
Moving.....
.Moving.....
closed loop is when the car is warmed up to opporating temps and after a certain predetermined time period of something around 3 minutes has passed. basically its the point where the oxygen sensors are hot enough to work accruately and begin feeding information back to the PCM. in closed loop the PCM is attempting to constantly maintain an AFR of 14.7:1 which if you are familiar with chemistry is the stoicheometric ratio where all the fuel and oxygen are consumed in the reaction. this of course will yeild the best fuel economy b/c you arent wasting gas. the oxygen sensors are what the PCM uses to measure the amount of oxygen left over in the reaction so the PCM knows whether to add or subtract fuel to maintain the target closed loop AFR of 14.7:1.
open loop is simply when the car is cold, the oxygen sensors are cold. because the sensors are cold they cannot read accurately so the PCM just ignores their output until that certain temp and time period has been reached like i mentioned before.
There is a simplified explanation of all this in the "Air/Fuel Management" section of my ScanMaster writeup.
Thanks Fred, I learnd a couple things from that reply...
I didnt know it could reach closed loop as low as 120 degrees.
I had never heard of the (PE) mode but I knew it wasn't exactly the same as open loop.
"Not sure I follow this at all. When the engine is cold, it is usually in an enriched state, based on coolant temp... much like a "choke" on a carb. Otherwise, the PCM is still trying to achieve 14.7:1. "
like you said it is in an enriched state. running slightly richer than 14.7:1 should in theory mean slightly better power.
I had no idea that the Stock tuning dropped the A/F raito as low as 11.7 to one. I thought anything below 12.5 was counterproductive.
"There is no real evidence that lack of AIR will cause premature failure of cats. It will just prevent them from reaching operating temperature as fast."
If you have ever watched a 5 gas analyzer there is a huge difference in HCs in open loop vs closed loop. The excess HCs could cause pre-mature cat failure.....And I'm told if you pull the air pump fuse the car will stay in open loop. I've never tested this though. A friend with a 95 camaro said he was having problems and the car would die as soon as it tried to go into open loop. And he said pulling the air pump fuse keeps the car in open loop, till he had time to fix it.
Thanks for the corrections...
